[GRASSLIST:8253] Re: i.ortho.photo cant select existing imagery group
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue Sep 13 04:09:54 EDT 2005
On Tue, 13 Sep 2005, Hartmut wrote:
>>> I don't want to add/remove any raster layer from the
>>> group, just want to tell i.ortho.photo which group it
>>> should use. How to do with this dialog-window?
>> i.ortho.photo both from the command prompt and from the d.m menu should
>> launch a prompt which asks you which which group you want to use.
> sorry, at least the cmd-line version doesn't ask for a group
> (call from d.m I didn't try yet). It just shows the group last used.
If you want the command to run using the command-line parser rather than
the GUI box, set the environment variable GRASS_UI_TERM to any value and
then run the command by typing its name alone. This should work more like
you are used to from earlier versions of GRASS.
Paul
