[GRASSLIST:8262] Re: i.ortho.photo cant select existing imagery group
Hartmut lada2hell at yahoo.de
Tue Sep 13 13:15:18 EDT 2005
> If you want the command to run using the command-line parser rather than the
> GUI box, set the environment variable GRASS_UI_TERM to any value and then run
> the command by typing its name alone. This should work more like you are used
> to from earlier versions of GRASS.
thank you for this hint!
Tried it, but unfortunately my problem doesn't depend on running
i.group in the term or the dialog-box - the functionality
was changed and the program is not suitable to select a group anymore.
Hartmut
