[GRASSLIST:8303] Setting Null Values
Dave Kent
dkent at sasktel.net
Thu Sep 15 23:47:27 EDT 2005
Hi:
I have some scanned topographic maps in geotiff format. When I try
to import them, r.in.gdal tells me that they are not orthogonal and I
need to straighten them with gdalwarp. This works fine but as the
map is rotated, I get black slivers along the edges of the maps.
I want to patch the maps together. If I set the black slivers to
NULL with r.patch -z or r.null the valid black content in the map
disappears as well.
Is there a way I can use the -dstnodata feature of gdalwarp to set
the 'nodata' portions of the output map directly to a NULL value that
grass will recognize on input?
Or is there some other way to solve this problem?
Thanks for your help.
Dave
