[GRASSLIST:8312] Re: BSQ import question
Bruno GUILLAUME guib at aero.obs-mip.fr
Fri Sep 16 06:44:23 EDT 2005
Dear Markus Neteler,
I have a problem related to the previous discussion about "BSQ import
question" : actually, I plan to import exactly the same database in
GRASS5 and following the answer that you gave, I installed gdalinfo and
I tried:
gdalinfo -mm gl-latlong-1km-landcover.bsq
and it returns me:
ERROR 4: `gl-latlong-1km-landcover.bsq' not recognised as a supported file format.
For info, I try this on my Suse 9.3 Linux version. I also run grass5.0.3
trying a "r.in.gdal" and I got returned the same answer from GRASS.
I recompiled the libgdal.so (I downloaded gdal-1.3.0.tar.gz
<http://www.gdal.org/dl/gdal-1.3.0.tar.gz> from
"http://www.gdal.org/dl/" and I also gdal-1.2.1.tar.gz
<http://www.gdal.org/dl/gdal-1.3.0.tar.gz> ) but nothing changed.
Any idea of what is going wrong ?
Thanks,
Bruno Guillaume.
Markus Neteler wrote:
>(cc GDAL list, due to potential ENVI driver issues
> ref:
> http://xserve.flids.com/pipermail/gdal-dev/2004-May/005648.html
> Sorry if you receive it twice.
>[ The question was how to import a BSQ file into GRASS.
>  I'll suggest to create an ENVI hdr file ]
>On Tue, Aug 03, 2004 at 09:20:36AM -0600, C.S. Cornuelle wrote:
>>Yes, I know, use i.tape.other.  :^)
>>The problem (hopefully) is that I do not know some of the particulars
>>which i.tape.other requires.  The file to import is
>>from
>>	http://glcfapp.umiacs.umd.edu:8080/esdi/index.jsp
>The global land cover file is at:
> ftp://ftp.glcf.umiacs.umd.edu/glcf/Global_Land_Cover/Global/gl-latlong-1km-landcover/
> Information
> Image Size: 				43200 Pixels 21600 Lines
> Quantization:			    8-bit unsigned integer
> Output Georeferenced Units: LONG/LAT E019
> Projection:    				Geographic (geodetic)
> Earth Ellipsoid:			Sphere, rad 6370997 m
> Upper Left Corner:			180d00'00.00" W Lon90d00'00.00" N Lat
> Lower Right Corner:			180d00'00.00" E Lon 90d00'00.00" S Lat
> Pixel Size (in Degrees):	0.00833 Lon 0.00833 Lat
> (Equivalent Deg,Min,Sec):	0d00'30.00"0d00'30.00"
> UpLeftX:					-180
> UpLeftY:      				90
> LoRightX:        			180
> LoRightY:      				-90
>-> note the Sphere!
>This is relevant for the definition of the location.
>See 'gl-latlong-1km-landcover.grasslocation.txt' attachment for details.
>>Some of you are probably familiar with this.  Assuming this, I
>>have a few questions from GRASS 5.3.
>>Any ideas?  Has anyone worked with this data set?  I'm running this on
>>a linux box, if it matters.
>Use r.in.gdal instead. It's way easier. You just have to generate
>a BSQ ENVI header file, then import the map (find attached the file).
>I hope I got that file right, following
> http://glcf.umiacs.umd.edu/data/guide/fileformat/bsq.shtml
> => RSI ENVI 3.6
>    However, I didn't set bands = 14 but bands = 1
>Now check with 'gdalinfo':
>Driver: ENVI/ENVI .hdr Labelled
>Size is 43200, 21600
>Coordinate System is:
>LOCAL_CS["Geographic Lat/Lon",
>    UNIT["Meter",1]]
>Origin = (-180.000000,90.000000)
>Pixel Size = (0.00833333,-0.00833333)
>Corner Coordinates:
>Upper Left  (-180.0000000,  90.0000000)
>Lower Left  (-180.0000000, -90.0000000)
>Upper Right ( 180.0000000,  90.0000000)
>Lower Right ( 180.0000000, -90.0000000)
>Center      (  -0.0000000,   0.0000000)
>Band 1 Block=43200x1 Type=Byte, ColorInterp=Undefined
>    Computed Min/Max=0.000,13.000
>IMHO the projection is not detected completely by GDAL,
>or should it be LOCAL_CS?
>If you prefer, you can also make it a GeoTIFF file,
>fixing the projection description in this moment:
>gdal_translate -a_srs '+init=esri:37008' \
>       gl-latlong-1km-landcover.bsq gl-latlong-1km-landcover.tif
>gdalinfo -mm gl-latlong-1km-landcover.tif
>Driver: GTiff/GeoTIFF
>GEOGCS["unnamed ellipse",
>    DATUM["unknown",
>        SPHEROID["unnamed",6370997,1]],
>    PRIMEM["Greenwich",0],
>    UNIT[,0.0174532925199433]]
>Corner Coordinates:
>Band 1 Block=43200x1 Type=Byte, ColorInterp=Gray
>Then import:
>(color table from
> http://glcf.umiacs.umd.edu/data/landcover/data.shtml
>r.in.gdal in=gl-latlong-1km-landcover.tif out=gl-latlong-1km-landcover
>r.colors gl-latlong-1km-landcover col=rules <<EOF
>0       000 000 000
>1       001 100 000
>2       001 130 000
>3       151 191 071
>4       002 220 000
>5       000 255 000
>6       146 174 047
>7       220 206 000
>8       255 173 000
>9       255 251 195
>10      140 072 009
>11      247 165 255
>12      255 199 174
>13      000 255 255
>EOF
>d.mon x0
>d.rast.leg gl-latlong-1km-landcover
>Regards
> Markus Neteler
>ENVI
>samples = 43200
>lines   = 21600
>bands   = 1
>header offset = 0
>file type = ENVI Classification
>data type = 1
>interleave = bsq
>byte order = 0
>map info = {Geographic Lat/Lon, 1.0, 1.0, -180.0, 90.0, 0.00833333333333, 0.00833333333333, sphere, units=Degrees}
>band names = {
>Band 1}
>gl-latlong-1km-landcover location.
>  Please specify the coordinate system for location <sphere>
>  B   Latitude-Longitude
>  you wish to specify a geodetic datum for this location?(y/n) [y] y
>  Please specify datum name
>  Enter 'list' for the list of available datums
>  or 'custom' if you wish to enter custom parameters
>  Hit RETURN to cancel request
>  > [nothing]
>  Please specify ellipsoid name
>  Enter 'list' for the list of available ellipsoids
>  >sphere
>  Radius: 6370997
>  Location boundaries:
>                       ====== DEFAULT REGION =======
>                       | NORTH EDGE:90N_______     |
>            WEST EDGE  |                           |EAST EDGE
>            180W______ |                           |180E______
>                       | SOUTH EDGE:90S_______     |
>           PROJECTION: 3 (Latitude-Longitude)         ZONE: 0
>                             GRID RESOLUTION
>                                 East-West:     0:00:30___
>                               North-South:     0:00:30___
