[GRASSLIST:8325] Re: Editing data in GUI
Mon Sep 19 01:37:52 EDT 2005
> > What is the easiest way to edit point co-ordinates and associated
> > data in GUI. If I imported point using v.in.ascii, and found on
> > displaying resulting map, that one point need to be corrected, then
> > can I click that point and then change co-ordinates? I could not
> > find such option.
'd.what.vect -e' is by far the easiest way.
> v.digit (freezing and crashing)
> QGIS Grass digit plugin
For me, v.digit has never been /that/ bad.. I've used it quite a bit and
only had a crash after digitizing ~600 points in one session while at
the same time displaying the same points with d.vect in a background
command. Makes me wonder if there is something with your setup that
triggers a bug that I don't see?
Hamish
