[GRASSLIST:8326] Re: changing projection
Morten Hulden
morten at untamo.net
Mon Sep 19 05:39:59 EDT 2005
s99171059 at tuks.co.za wrote:
> But now, when I r.proj the raster, I get the message that it doesn't fit the
> region, or something like that. To fix this, I select the 'Dont crop...'
> button. The projection is done, but when I want to display the raster, I get a
> blank window. I also tried to set the region to the raster map, but this didn't
> help.
The message "Input map is outside current region" is there to tell you
exactly that. You should check the settings of your location and map.
Morten
