[GRASSLIST:8297] Re: changing projection
s99171059 at tuks.co.za s99171059 at tuks.co.za
Thu Sep 15 14:40:13 EDT 2005
Thanks, Stephan,
But now, when I r.proj the raster, I get the message that it doesn't fit the
region, or something like that.  To fix this, I select the 'Dont crop...'
button.  The projection is done, but when I want to display the raster, I get a
blank window.  I also tried to set the region to the raster map, but this didn't
help.
Any other ideas will be appreciated.
Quoting Stephan Holl <holl at gdf-hannover.de>:
> Hello Kobus,
> On Thu, 15 Sep 2005 08:50:31 +0200 (SAST) s99171059 at tuks.co.za wrote:
> > I created a new location, and chose tmerc as my projection.  Then I
> > simply imported the ERDAS .img, with the 'Override projection (use
> > location's projection)' flag set.  Will my ERDAS file now be
> > converted to the correct projection, or will the data of the image
> > not correlate with the projection info?
> The latter is the case. Some needed steps in short:
> * import your .img with r.in.gdal in=my.img loc=newlocation
> * create a new location with your target-projection definition
> * enter your newly created target location
> * use r.proj to transform from your UTM-loc into your newly created
> tmerc-location.
> Hope that helps
> Best regards
> 	Stephan
> GDF Hannover - Solutions for spatial data analysis and remote sensing
> Hannover Office      -     Mengendamm 16d      -     D-30177 Hannover
> Internet: www.gdf-hannover.de      -      Email: holl at gdf-hannover.de
> Phone : ++49-(0)511.39088507       -        Fax: ++49-(0)511.39088508
