[GRASSLIST:8353] Re: v.in.garmin
    Leonardo Lami
    lami at faunalia.it
    Tue Sep 20 04:30:43 EDT 2005
Hi Hamish,
Hi list,
Probably the problem was in using commas for decimal places so you said.
Now the new version works well.
Also a little error about the control on gps device is ok.
In the  GRASS 6.1.x (develop version) a "-p" preceded the name of the driver
and so the driver was not known.
Thanks for the help
Best regards
Leonardo
Alle 09:31, martedì 20 settembre 2005, hai scritto:
> > I see that v.in.garmin script in GRASS 6.1.x (develop version) is
> > broken, the  rigth script is only in GRASS 6.0.1 (stable version).
> I was not aware that it was broken. Can you explain what is wrong?
> Probably your locale using commas for decimal places, which makes awk
> choke. This should be fixed by Moritz Lennert a few hours ago, can you
> update, test and report back working/not working?
> >From a design perspective I am surprised that the specific
> (LC_NUMERIC) doesn't override the generic (LC_ALL) setting.
> but,
> "LC_NUMERIC
>     In the absence of LC_ALL, LC_NUMERIC chooses the numeric format
> locale. In the absence of both LC_ALL and LC_NUMERIC, LANG chooses the
> numeric format."
> If that's how it is, that's how it is.... shrug.
> devels & international scripters:
>  I have cleaned up & sync'ed the latest changes. messy! tsk tsk. :-)
> Now both 6.1-cvs and 6.0.x versions are the same, be they broken or
> fixed. Untested as the GPS I usually use is in the field currently
> and I'm just different versions of en_* anyway.
> rather than:
> unset LC_ALL
> export LC_NUMERIC=C
> should we just do:
> export LC_ALL=C
> or is it better to 'unset LC_ALL' and let LANG fill in the other blanks?
> > Can you exchange it?
> yes, just copy over the file into $GISBASE/scripts/.
> I don't understand why the 6.0.1 version would work when the 6.1cvs
> version didn't though.. The 6.0.1 version wasn't unsetting LC_ALL
> either. Moreover I seem to remember getting a positive outcome when we
> added LC_NUMERIC when this first came up. Maybe different platform
> different issues.. regardless, hopefully it is working ok now.
> The script WAS broken in 6.0.0.
> Hamish
Leonardo Lami
lami at faunalia.it            www.faunalia.it
Via Colombo 3 - 51010 Massa e Cozzile (PT), Italy   Tel: (+39)349-1310164
GPG key @: hkp://wwwkeys.pgp.net http://www.pgp.net/wwwkeys.html
https://www.biglumber.com
