[GRASSLIST:8361] Remote execution of grass53 commands
    Suprit Kumar
    suprit at darya.nio.org
    Tue Sep 20 12:52:37 EDT 2005
Hi all,
First let me give some background information.
I am using grass-5.3.0 on my PC (Pentium P4) running on mandrake 10.0 Linux.
We have few linux PCs (running too on mandrake 10.0) where grass-5.3.0 is
installed.
I am planning to run s.vol.rst module for interpolating daily rainfall values
for some years.
To save time (as it takes considerable time) I wanted to write a script that
will fire a job for diffrent time periods on different PCs from my PC.
The problem starts when I tried to remotely execute the commands from a
script using ssh.
Here is example of the script and output,
#!/bin/bash
#First I have to start a grass session on remote machine "chambal"
ssh chambal grass53 /home/suprit/grass53/GrassData/globe/goa
# Then next grass command as.
g.region raster=goa_map_1 (# I tried "ssh chambal g.region raster=goa_map_1"
too.)....
This gives out output as shown below, the shell prompt is not returned and the
next command (g.region raster=goa_map_1)  does not get executed at all.....
When I kill the Grass session by ctr-c only then g.region gets executed giving
obvious error   "ERROR: GISBASE not set"
---output---
Cleaning up temporary files.....$TERM
Starting GRASS ...
>tput: No value for $TERM and no -T specified (both -T i specified and
$TERM=xterm here
Welcome to GRASS 5.3.0 (15 May 2004)....
This version running thru the Bash Shell (/bin/bash)
Help is available with the command:      g.manual
See the licence terms with:              g.version -c
Start the graphical user interface with: tcltkgrass&
When ready to quit enter:                exit
Am I doing something horribly wrong or there is some settings to be changed?
Any suggestions and help is welcome.
Thanks in advance,
With best regards
Suprit
Suprit Kumar
JRF,
National Institute of Oceanography,
Dona Paula-403 004, Goa, INDIA.
email:suprit at nio.org
Tel. : +91-(0)832-2450-400
Fax. : +91-(0)832-2229102
