[GRASSLIST:8368] Re: New GIS Manager version
    Ian MacMillan
    ian_macmillan at umail.ucsb.edu
    Wed Sep 21 10:09:06 EDT 2005
Michael, I have only one raster in the GIS manager when I do this.  If
I put a grayscale shaded relief map in the first, and an air photo in
the second, then I get an 'his' display that is later covered by just
the first map.  I have attached a small jpg that shows what I am
talking about.  This screen shot shows my 'his' image getting covered
up by the  shaded relief map (the shaded relief map does not extend all
the way to the outer bottom right edge).  For some reason it looks like
I am getting something like
d.his h_map=air_photo i_map=shaded_relief
d.rast shaded_relief -o
rather than just the d.his command when I hit the display button.
I am also using the binaries from Lorenzo (Sept. 17 - source, Sept. 19
- osx).  That is weird that you can't reproduce this.
-Ian
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20050921/3c4e850e/amboy.jpg
On Sep 20, 2005, at 11:40 PM, Michael Barton wrote:
> Ian,
> You are correct that a version of d.his is called when you drape or
> fuse
> maps.
> I just checked this with the version of Lorenzo's binaries I downloaded
> today, with the new GIS Manager installed.
> It seemed to work exactly as you'd expect it to work. I added a dem to
> the
> 1st raster map entry field and an ASTER image to the second. I got the
> ASTER
> shaded by topography. I reversed them and got an image that looked
> pretty
> similar. Do you have another layer in the GIS Manager that is
> overwriting
> the first one?
> I have the overlay checkbox selected by default in all raster layers.
> But if
> you turn it off, a layer will overwrite all preceeding layers.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Ian MacMillan <ian_macmillan at umail.ucsb.edu>
>> Date: Tue, 20 Sep 2005 17:06:10 -0700
>> To: GRASS Users List <grasslist at baylor.edu>
>> Subject: [GRASSLIST:8365] Re: New GIS Manager version
>> Hey there Michael, fantastic job on the new GIS Manager.  Looks great
>> so far.  I have a question about the functionality of the d.rast
>> button.  In the menu options there is a button that says 'Raster to
>> drape over 1st map'.  This seems like an approximate d.his utility.
>> However I don't quite understand how it works.  Say if I have map1
>> (air
>> photo) under 'Raster name' and map2 (DEM) under the second button,
>> then
>> when I display the image I get what I think is my colored DEM  with
>> shading from my black and white air photo.  This then gets covered up
>> by map1 (the monitor displays two images overlain on top of each
>> other).
>> Does my explanation make sense?  Is that second raster not supposed to
>> display?  How does this button differ from d.his?
>> Cheers,
>> Ian
>> PS using mac 10.3.9
>> What happens if a big asteroid hits Earth? Judging from realistic
>> simulations involving a sledge hammer and a common laboratory frog, we
>> can assume it will be pretty bad.
>>   - Dave Barry
>> This message has been scanned by Postini anti-virus software.
  - Dave Barry
