[GRASSLIST:8384] oft: image and report in postgres
    ivan marchesini
    marchesini at unipg.it
    Thu Sep 22 14:55:19 EDT 2005
Dear Users,
I have worked on a grass-postgres system and finally I have obtained my
geographical database...
now each area feature in the map is connected to a record in a table
that contains a lot of fields....
Now I would like to insert a new field (an OID field for example) to
store the photographic aerial snapshot of each area in the map (I will
write a script to collect this image for each feature)
I know that I can import the images into the OID field using the
lo_import command but the problem is:
how can I generate a report of the obtained table which contain the
tabular data of each area feature and also the aerial image???
I would like to obtain a report constituted by a number of pages equal
to the number of area features, and I would like to have in each page
the ID of the area feature, the aream the perimeter, but overall the
aerial image!!!!
I have tried to use OpenOffice (that I have connected to postgreSQL) and
PGaccess to create reports containing the image field but I have hadn't
success!!!
can you suggest me a different procedure??? or a way to solve my
problem???
thank you very much
Ivan
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
