[GRASSLIST:8383] Re: v.to.rast3
Radim Blazek
radim.blazek at gmail.com
Thu Sep 22 12:04:07 EDT 2005
On 9/22/05, Stefania Merlo <sm399 at cam.ac.uk> wrote:
> Dear all and dear Radim (who incorporated the command in the cvs version),
> you wrote about the above command the following:
> Note that raster mask is ignored and if multiple points fall into the same
> cell the last values used and if one point has more cats, the first is used.
> About the cats, does it mean that it will use the first cat no matter if I
> give it the name of the column where the value to be used is?
No, forget about it.
> I tried to experiment with the command but it seems not to do what I need.
> >From what I understand of the process, it is not processing the data fully.
> Is it beacause i have 20000 entries?
Are you missing points in debug output (col,row,depth,val: ......)?
Radim
> Let me explain the data a bit better. It is an ascci files with x,y,z
> coordinates of grid conjunction points used for excavation and then three
> columns with different weight values of different material. What I want to
> display is the voxel with the correspondent weight value. Am I doing
> something wrong? Do not tell me I have to interpolate because this is not
> what I want to do, as every voxel represents for me the dug unit and its
> content.
> Stefania Merlo
> Department of Archaeology
> University of Cambridge
> United Kingdom
> e-mail: sm399 at cam.ac.uk
> Office: +44 1223 763518
> Mobile: +44 787 6405064
