[GRASSLIST:599] Re: How to Run GRASS modules at bash prompt
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Thu Apr 6 08:12:32 EDT 2006
Nagesh,
GRASS 6.1.cvs consumes a tiny total of ca. 72 MB on your hard disk
drive. With 320 GB disks costing around 150$,
are you sure it will be worth the trouble figuring all this out
to save a few megabytes? Won't it be easier to convince your
boss to just install GRASS?
Once that is done, it is easy to write scripts that start a
GRASS shell session, then carry out whatever action you want
them to.
Best,
Benjamin
Nagesh Bhatkar wrote:
> Dear GRASS users,
> One of my colleagues wanted to edit the islands out. I suggested him to
> use GRASS to edit the islands (d.rast.edit). But he didnt want me to
> install the entire GRASS because it
> would result in unneccesary consumption of memory as he wanted to use
> only one module of GRASS and didnt want other modules. So he asked me if
> i could install only the GRASS modules , libraries , which were needed
> by the d.rast.edit module which could work outside the GRASS enviroment
> at the bash prompt.
> I modified the existing d.rast.edit module to delete insignificant
> islands(in the relative sense)
> which were causing some errors in the model we were running. By this
> module , Onclick anywhere,
> determines if its a island and if it is gives the option to delete the
> entire island i.e set as ocean instead of editing each individual cell out.
> I wanted to know if i cud use GRASS modules at bash command  prompt. I
> went through the GRASS SWIG/PERL implementation grass_warp.c .
> But didnt quiet understand how i could implement it.
> I have read and understood all the makefiles in
> ~/grass-6.0.1/include/Make/  and the init.sh file.
> kindly drop in suggestions if using GRASS modules at bash prompt is
> possible and what i need to
> do to accomplish that.
> Nagesh
> <http://mpa.itc.it/markus/grass61progman/swig/grass__wrap_8c.html>
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeo-Information Science)
Institut für Ur- und Frühgeschichte
(Institute of Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
