[GRASSLIST:635] Re: 3d Vector in NVIZ?
Wolfgang wollez at gmx.net
Sat Apr 8 09:49:19 EDT 2006
Hello,
problem is already solved. The converter I used to create the shp worked
only in 2d! With an other converter I really get a 3d shp and that can
be displayed in nviz.
Sorry for confusing you!
Wolfgang
Jachym Cepicky schrieb:
> Hallo,
> On Tue, Mar 28, 2006 at 10:05:46PM +0200, Wolfgang Zillig wrote:
>> Hello,
>> I'm just starting with vector handling in grass, but I don't understand everything correctly.
>> Is ist possible to display a 3d linevector, which was imported from a shapefile in NVIZ?
>> My vect is called "cave" and I have also a dbf table called "cave". In the table several columns are available but I think I have
>> to link somehow the col "DXF_ELEVAT" which contains elevation data to my vector. But I'm lost.
>> I hope anybody can give me a hint what I have to do next.
>> Regards
>> Wolfgang
> Sorry, it took me so long time.
> Yes NVIZ is able to display your 3D-Vektor line. But I do not realy
> understand your problem.
> If your shape-file is allready 3D, you have to import it via v.in.ogr
> using the -z flag
>     v.in.ogr dsn=./cave.shp out=cave -z
> Or are your data looking different?
> Jachym
