[GRASSLIST:668] Re: off topic: backing up huge mapsets
Wolfgang wollez at gmx.net
Tue Apr 11 15:29:16 EDT 2006
If you are on windows then have a look for 7zip http://www.7-zip.org/
cheers
Wolfgang
Benjamin Ducke schrieb:
> tar --help:
>  Device selection and switching:
>   -f, --file=ARCHIVE         use archive file or device ARCHIVE
>       --force-local          archive file is local even if has a colon
>   -F, --info-script=NAME, --new-volume-script=NAME
>                              run script at end of each tape (implies -M)
>   -L, --tape-length=NUMBER   change tape after writing NUMBER x 1024 bytes
>   -M, --multi-volume         create/list/extract multi-volume archive
>       --rmt-command=COMMAND  use given rmt COMMAND instead of rmt
>       --rsh-command=COMMAND  use remote COMMAND instead of rsh
>       --volno-file=FILE      use/update the volume number in FILE
> ... so options -L and -M should be what you are looking for?
> Benjamin
> Jaime Carrera wrote:
>> Hi all,
>> I know this is off topic but probably some of you had experienced this
>> problem as well. I have a very large mapset (19 GB) which is not
>> compressed by using bz2 (the final tar.bz2 file was 17.2 GB). I have a
>> backup of this mapset on an USB hard disk but I would like to create
>> another copy in a couple of double layer DVDs (I don't want to take
>> any chances with the data that I have). Does someone know how to
>> create three smaller files which I can later burn on separate DVDs?
>> thanks,
>> Jaime
>> __________________________________________________
>> Correo Yahoo!
>> Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
>> Regístrate ya - http://correo.espanol.yahoo.com/
