[GRASSLIST:663] Re: off topic: backing up huge mapsets
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Tue Apr 11 12:11:25 EDT 2006
tar --help:
Device selection and switching:
-f, --file=ARCHIVE use archive file or device ARCHIVE
--force-local archive file is local even if has a colon
-F, --info-script=NAME, --new-volume-script=NAME
run script at end of each tape (implies -M)
-L, --tape-length=NUMBER change tape after writing NUMBER x 1024 bytes
-M, --multi-volume create/list/extract multi-volume archive
--rmt-command=COMMAND use given rmt COMMAND instead of rmt
--rsh-command=COMMAND use remote COMMAND instead of rsh
--volno-file=FILE use/update the volume number in FILE
... so options -L and -M should be what you are looking for?
Benjamin
Jaime Carrera wrote:
> Hi all,
> I know this is off topic but probably some of you had experienced this
> problem as well. I have a very large mapset (19 GB) which is not
> compressed by using bz2 (the final tar.bz2 file was 17.2 GB). I have a
> backup of this mapset on an USB hard disk but I would like to create
> another copy in a couple of double layer DVDs (I don't want to take any
> chances with the data that I have). Does someone know how to create
> three smaller files which I can later burn on separate DVDs?
> thanks,
> Jaime
> __________________________________________________
> Correo Yahoo!
> Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
> Regístrate ya - http://correo.espanol.yahoo.com/
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeo-Information Science)
Institut für Ur- und Frühgeschichte
(Institute of Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
