[GRASSLIST:661] Re: off topic: backing up huge mapsets
Curt, WE7U archer at eskimo.com
Tue Apr 11 11:56:05 EDT 2006
On Tue, 11 Apr 2006, Jaime Carrera wrote:
>  I know this is off topic but probably some of you had experienced
>  this problem as well. I have a very large mapset (19 GB) which is
>  not compressed by using bz2 (the final tar.bz2 file was 17.2 GB).
>  I have a backup of this mapset on an USB hard disk but I would
>  like to create another copy in a couple of double layer DVDs (I
>  don't want to take any chances with the data that I have). Does
>  someone know how to create three smaller files which I can later
>  burn on separate DVDs?
If you just want to chop the file up in a way that you can put them
together later to play with it (each segment won't be usable as-is),
then use either the Unix "split" command or the "dd" command.  You
can specify how many bytes to split at.  See the man pages for each.
Curt, WE7U.   APRS Client Comparisons: http://www.eskimo.com/~archer
"Lotto:    A tax on people who are bad at math." -- unknown
"Windows:  Microsoft's tax on computer illiterates." -- WE7U
"The world DOES revolve around me:  I picked the coordinate system!"
