[GRASSLIST:677] Re: How to program a little script
giglio.antonio at katamail.com giglio.antonio at katamail.com
Wed Apr 12 05:21:01 EDT 2006
First of all thank you for replying!
I studied r.cost and r.walk, but still can't find a solution...
I try to use r.cost for creating a cost map, but it doesn't recognize coordinates in the format xx:xx:xx.x (i.e. 81:27:41.1 -N-).
Anyway I don't know how (and if) that cost map can be used for what I need...
r.walk also seems to be useful, but I have troubles to realize which kind of cost map
is the more suitable.
Thank you again,
Antonio Giglio
> Da: Hamish <hamish_nospam at yahoo.com>
> Data: Fri, 7 Apr 2006 13:40:59 +1200
> A: "giglio.antonio at katamail.com" <giglio.antonio at katamail.com>
> Oggetto: [GRASSLIST:617] Re: How to program a little script
> > I have to program a little script that, starting from 2 points (A and
> > B) on a raster map (a DEM), calculate first 3 shortest going-down
> > paths (from A to B). It seems to be easy, but this is the first time i
> > try to program GRASS and I don't know how to proceed.
> see r.cost, r.walk
> Hamish
