[GRASSLIST:681] Re: height contour lines to raster
Wolfgang
wollez at gmx.net
Wed Apr 12 07:05:24 EDT 2006
that shape file contains height-contour lines, and I need it as regular
raster map for an other software.
Cheers
Wolfgang
Luca Casagrande schrieb:
> Probably didn't understand your question...
> If you mean to import a vector file that has got an "height" value in is tab
> and then convert to raster with value as the "height", i did it with no
> problem...
> Luca
> Alle 11:54, mercoledì 12 aprile 2006, Wolfgang ha scritto:
>> Hello,
>> I assume that the conversion of a vector map which contains height lines
>> to a raster map is possible is possible with v.to.r? I ask because I
>> would have to buy that file first.
>> Thanks für any reccomendation!
>> Cheers
>> Wolfgang
