[GRASSLIST:698] Re: MIF import and thematic maps
Michael Barton
michael.barton at asu.edu
Thu Apr 13 01:49:55 EDT 2006
Import MIF/MID using v.in.ogr.
I've done it and it works fine provided the MIF is not corrupted.
For color, simply put the RGB values into an attribute column/field you name
GRASSRGB (all caps) or specify with the rgb_column option in d.vect. Then
display with d.vect setting the -a flag.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maciek Sieczka <werchowyna at epf.pl>
> Date: Wed, 12 Apr 2006 21:10:53 +0200
> To: T_gl_sy_rs <orsteglasy at yahoo.com>
> Cc: <grasslist at baylor.edu>
> Subject: [GRASSLIST:691] Re: MIF import and thematic maps
> On Wed, 12 Apr 2006 11:28:36 -0700 (PDT)
> "T_gl_sy" "_rs" <orsteglasy at yahoo.com> wrote:
>> Hi there,
>> Q1: I have a mif/mid layer imported into grass60 containing
>> polygons. There is a table containig IDs for the polygons. And there
>> is an MS Excel (xls) table containing IDs and RGB and CMYK values as
>> the filling colour of those polygons. Mad enough I know, but is there
>> a way to paint those polygons with the colour values described in the
>> xls?
> Copy RGB tripplets to your Grass vector's column of some name, use
> d.vect rgb_column=string
>> Q2: Is there a way to import text from a MIF file? I tried it,
>> but I cannot see anything!
> Don't know. As it seems more about the OGR driver than Grass, you could
> find info on GDAL/OGR site/mailing list.
> Maciek
> W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko
> najlepsze z nich!
> http://katalog.panoramainternetu.pl/
