[GRASSLIST:701] Re: MIF import and thematic maps
Thu Apr 13 07:28:42 EDT 2006
> For color, simply put the RGB values into an attribute column/field
> you name GRASSRGB (all caps) or specify with the rgb_column option in
> d.vect. Then display with d.vect setting the -a flag.
Note d.vect now has a rgb_column= option so the RRR:GGG:BBB column
doesn't have to be called "GRASSRGB". More importantly you can now have
two RGB columns, eg for two different parameters at the same site.
"GRASSRGB" still the default of course.
Hamish
