[GRASSLIST:709] Re: MIF import and thematic maps
Michael Barton
michael.barton at asu.edu
Thu Apr 13 10:40:01 EDT 2006
Correct. I didn't explain this clearly enough. This makes it quite
versatile.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Hamish <hamish_nospam at yahoo.com>
> Date: Thu, 13 Apr 2006 23:28:42 +1200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: <werchowyna at epf.pl>, <orsteglasy at yahoo.com>, <grasslist at baylor.edu>
> Subject: Re: [GRASSLIST:698] Re: MIF import and thematic maps
>> For color, simply put the RGB values into an attribute column/field
>> you name GRASSRGB (all caps) or specify with the rgb_column option in
>> d.vect. Then display with d.vect setting the -a flag.
> Note d.vect now has a rgb_column= option so the RRR:GGG:BBB column
> doesn't have to be called "GRASSRGB". More importantly you can now have
> two RGB columns, eg for two different parameters at the same site.
> "GRASSRGB" still the default of course.
> Hamish
