[GRASSLIST:755] Re: epsg location creation
    Francesco Mirabella
    mirabell at unipg.it
    Wed Apr 19 03:27:22 EDT 2006
Hi Maciek and Hamish,
thanks for your reply,
I checked and the error is the same both in 6.0.1 and 6.0.2.
In 6.1 cvs (on cygwin) it works fine, so I guess it is ok also in the non-cygwin.
However, at least in cygwin, the path to epsg is wrong as it is in
</usr/share/proj/epsg> and not in </usr/local/share/proj/epsg> as
suggested. Maybe this can help
thanks to all
cheers
Francesco
On Wed, Apr 19, 2006 at 12:00:23PM +1200, Hamish wrote:
> > > I need to create an epsg location to import som vector data.
> > > I am using grass 6.0.1 on debian testing.
> > > It looks simple, but in fact after inserting the epgs code number of
> > > projection (from the epsg list), the new location is not created.
> > > Can someone tell me what is wrong??
> > Francesco,
> > Does this answer your question?
> > http://thread.gmane.org/gmane.comp.gis.grass.devel/10465/focus=10541
> > Have you checked with 6.1 (it is fixed there)? I don't remember if the
> > fix was backported to 6.0x but try it if you can and let us know
> > http://grass.meteo.uni.wroc.pl/grass60/source/snapshot/.
> There is a GRASS 6.1-cvs binary for Debian/testing at DebianGIS.
> (don't know if newer than 9 Feb)
>   http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl
> Hamish
