[GRASSLIST:761] Problem GRASS-6.0.2
    Nagaraj Thanushkodi
    Nagaraj.Thanushkodi at rmsi.com
    Wed Apr 19 07:58:41 EDT 2006
Hello,
I have a installed grass-6.0.2 on a linux FC4 machine. Configuration of
this machine is as 1.4Ghz processor, 512MB RAM, 70GB  (SCSI HDD) and FC4 is
the only OS on the machine, also the swap space provided to the OS is of
1.5 GB.
The problem that I am facing  is I am unable to use >=2gb ESRI Arc/Info
ASCII Grid Raster dataset. It seem to keep reporting an error  that "File
too large" .
After exploring the net for the same I came to know that while
configuration the --enable-64bit=yes for enabling the Grass to read >2GB
dataset and make and make install.
Even after doing so the grass still is not able to accept dataset >=2gb.
If anyone know how to make r.in.arc read file >=2gb.
Regards
Nagaraj
