[GRASSLIST:813] Re: v.clean and rmarea parameter
    Hamish
    hamish_nospam at yahoo.com
    Sat Apr 22 03:41:59 EDT 2006
> > I want to remove small areas with v.clean, but there is a problem and
> > I don't know how to solve it.
> > In simple terms I would need a sql parameter in v.clean to determine
> > with which adjacent areas (values, ids,...) the boundary should be
> > removed. Since this is not included in v.clean, does anybody has a
> > workaround for this?
> > To better understand the problem I have an illustration here:
> > http://www.gdf-hannover.de/dassau/muell/vclean_rmarea.png
> How about v.extract -d. There are nice examples in the manual.
You also might a "v.to.db option=sides" step first, then v.extract.
Hamish
