[GRASSLIST:830] Re: NVIZ image dumps
Hamish
hamish_nospam at yahoo.com
Mon Apr 24 00:35:51 EDT 2006
> I am using GRASS 6.1.cvs, updated 2006-04-23
> Kernel: Linux 2.6.15-1-amd64-k8
> CPU: AMD Athlon 64 3700+
> Video Card: ATI Technologies Inc RV410 [Radeon X700 Pro (PCIE)]
> Video driver: fglrx-driver 8.19.10-1
> 1) Doing "Save Image As:" (any format except max. resolution) produces
> an image the size of the NVIZ image window with the top half black,
> and with copies of the desired image in each of the two lower
> quadrants. (See attached example)
> The appearance suggests to me that this might be a 64-bit issue.
> Is anyone else seeing this?
Works ok for me on a 32-bit P4.
Are you using a weird window manager?
What linux distro+version?
> 2) Save... max. resolution ppm causes NVIZ to crash with the following
> error:
> XIO: fatal IO error 14 (Bad address) on X server ":0.0"
> after 20394 requests (20394 known processed) with 0 events
> remaining.
> The number "20394" varies.
maybe this bug:
https://intevation.de/rt/webrt?serial_num=3041
For me it doesn't crash though, just gives bad output.
Hamish
