[GRASSLIST:847] Re: Live Earthquake Map: GRASS/PHP
pmarc paulomarcondes at gmail.com
Mon Apr 24 10:10:55 EDT 2006
> Did you try in the last 12 hours? I changes a bit (and
> observe a nice USGS map bug with only negative Longitudes...)
Yep, I tried this morning (it's still morning =D)
> I think that 2-3 seconds are acceptable - or how long does
> it take for you? My intention was to show real-time processing,
> not a batched one. Again, with the new server I try to reach
> the millisecond range :-)
Something in that range...
Except that now, at first no eathquakes were shown on the small map.
then, the hi-res image was showing lots of them...
I noticed that the grass/php map does not show anything below 0
latitude, the same as the USGS list, but not the same as USGS map...
I'm not sure if you were refering to that...
cheers.
Paulo Marcondes = PU1/PU2PIX
-22.915 -42.229 = GG87vc (http://www.amsat.org/cgi-bin/gridconv)
Debian GNU/Linux = http://rj.debianbrasil.org = http://www.debian.org
