[GRASSLIST:863] Re: NVIZ image dumps
Wolfgang wollez at gmx.net
Tue Apr 25 16:06:25 EDT 2006
Hello Maris,
for high quality output I would suggest using Povray. For a start you
can look at: http://casoilresource.lawr.ucdavis.edu/drupal/node/80 . But
it depends on what you want to achieve. I'm also willing to help. I'm
sill rendering my first animation which will be about 2 minutes long.
But as soon as it is available I will post the link to thee mailing list
  (preparation of SRTM data, the surface overlay and some vector
graphics are included).
Cheers
Wolfgang
Māris Nartišs schrieb:
> Hi,
> 32 bit box, can repeat crash on full res image (grass-6.1.cvs_src_snapshot_2006_03_25)
> screen dump as tiff and others - works as expected.
> Note. I was taking nviz screen dumps with KSnapshot. To get normal snapshot, I was using feature "take after XX sec delay", set delay to XX, click redraw in nviz and wait till it finishes to redraw screen and takes screenshot. When using output for animation, must be carefull as twice - it takes screen content at window coordinates -> cant move window, minimize or hide behind other window. It sucks, but works.
> Maris.
> Screen dump at max res output:
> Creating PBuffer Using GLX 1.3
> Final Assembled Image will be -1209881928 x -1217503232
> Writing Tile 1 of 81
> MALLOC Failed
> Writing Tile 2 of 81
> MALLOC Failed
> Writing Tile 3 of 81
> MALLOC Failed
> Writing Tile 4 of 81
> MALLOC Failed
> Writing Tile 5 of 81
> MALLOC Failed
> Writing Tile 6 of 81
> MALLOC Failed
> Writing Tile 7 of 81
> MALLOC Failed
> Writing Tile 8 of 81
> MALLOC Failed
> Writing Tile 9 of 81
> MALLOC Failed
> Writing Tile 10 of 81
> MALLOC Failed
> Writing Tile 11 of 81
> MALLOC Failed
> Writing Tile 12 of 81
> MALLOC Failed
> Writing Tile 13 of 81
> MALLOC Failed
> Writing Tile 14 of 81
> MALLOC Failed
> Writing Tile 15 of 81
> MALLOC Failed
> Writing Tile 16 of 81
> MALLOC Failed
> Writing Tile 17 of 81
> MALLOC Failed
> Writing Tile 18 of 81
> MALLOC Failed
> Writing Tile 19 of 81
> MALLOC Failed
> Writing Tile 20 of 81
> MALLOC Failed
> Writing Tile 21 of 81
> MALLOC Failed
> Writing Tile 22 of 81
> MALLOC Failed
> Writing Tile 23 of 81
> MALLOC Failed
> Writing Tile 24 of 81
> MALLOC Failed
> Writing Tile 25 of 81
> MALLOC Failed
> Writing Tile 26 of 81
> MALLOC Failed
> Writing Tile 27 of 81
> MALLOC Failed
> Writing Tile 28 of 81
> MALLOC Failed
> Writing Tile 29 of 81
> MALLOC Failed
> Writing Tile 30 of 81
> MALLOC Failed
> Writing Tile 31 of 81
> MALLOC Failed
> Writing Tile 32 of 81
> MALLOC Failed
> Writing Tile 33 of 81
> MALLOC Failed
> Writing Tile 34 of 81
> MALLOC Failed
> Writing Tile 35 of 81
> MALLOC Failed
> Writing Tile 36 of 81
> MALLOC Failed
> Writing Tile 37 of 81
> MALLOC Failed
> Writing Tile 38 of 81
> MALLOC Failed
> Writing Tile 39 of 81
> MALLOC Failed
> Writing Tile 40 of 81
> MALLOC Failed
> Writing Tile 41 of 81
> MALLOC Failed
> Writing Tile 42 of 81
> MALLOC Failed
> Writing Tile 43 of 81
> MALLOC Failed
> Writing Tile 44 of 81
> MALLOC Failed
> Writing Tile 45 of 81
> MALLOC Failed
> Writing Tile 46 of 81
> MALLOC Failed
> Writing Tile 47 of 81
> MALLOC Failed
> Writing Tile 48 of 81
> MALLOC Failed
> Writing Tile 49 of 81
> MALLOC Failed
> Writing Tile 50 of 81
> MALLOC Failed
> Writing Tile 51 of 81
> MALLOC Failed
> Writing Tile 52 of 81
> MALLOC Failed
> Writing Tile 53 of 81
> MALLOC Failed
> Writing Tile 54 of 81
> MALLOC Failed
> Writing Tile 55 of 81
> MALLOC Failed
> Writing Tile 56 of 81
> MALLOC Failed
> Writing Tile 57 of 81
> MALLOC Failed
> Writing Tile 58 of 81
> MALLOC Failed
> Writing Tile 59 of 81
> MALLOC Failed
> Writing Tile 60 of 81
> MALLOC Failed
> Writing Tile 61 of 81
> MALLOC Failed
> Writing Tile 62 of 81
> MALLOC Failed
> Writing Tile 63 of 81
> MALLOC Failed
> Writing Tile 64 of 81
> Writing Tile 65 of 81
> Writing Tile 66 of 81
> Writing Tile 67 of 81
> Writing Tile 68 of 81
> MALLOC Failed
> Writing Tile 69 of 81
> MALLOC Failed
> Writing Tile 70 of 81
> MALLOC Failed
> Writing Tile 71 of 81
> MALLOC Failed
> Writing Tile 72 of 81
> MALLOC Failed
> Writing Tile 73 of 81
> Writing Tile 74 of 81
> Writing Tile 75 of 81
> Writing Tile 76 of 81
> Writing Tile 77 of 81
> MALLOC Failed
> Writing Tile 78 of 81
> MALLOC Failed
> Writing Tile 79 of 81
> MALLOC Failed
> Writing Tile 80 of 81
> MALLOC Failed
> Writing Tile 81 of 81
> MALLOC Failed
> Assembling Tiles
> pnmcat: junk in file where an unsigned integer should be
> pnmcat failed to create assembled image
> Check that pnmcat is installed and path is set
> pnmcat: Error reading magic number from Netpbm image stream.  Most
> often, this means your input file is empty.
> pnmcat failed to create assembled images
> GLX -- destroy pbuffer
> On 4/25/06, Carl Brown <cbsled at verizon.net> wrote:
>> On Monday 24 April 2006 12:35 am, Hamish wrote:
>>> Works ok for me on a 32-bit P4.
>>> Are you using a weird window manager?
>>> What linux distro+version?
>> I received this report, but Lars didn't CC it to the list:
>>> I have the same problem; Suse 9.3 on AMD 64 bit machine ("homemade" PC
>> from
>>> standard components; NVIDIA graphics card)
>>> Mvh/Regards
>>> Lars Forseth
>> I'm running debian testing, KDE, no weird window manager.
>> The next question is:
>> Is anyone running any 64-bit system NOT seeing this problem?
>> Carl Brown
>> Whitefield, NH USA
