[GRASSLIST:876] Re: GMT / GRASS use / shp2gmt
Allan Hollander adh at ice.ucdavis.edu
Tue Apr 25 19:14:35 EDT 2006
Trevor,
I'm a rank beginner at GMT but in my one exercise to date with it I
learned the following. Mark Fenbers has modified the shp2gmt.c file to
include the attribute info from the dbf file into the multi-segment
separator of the psxy input file. His code is given in his message here:
http://www.mechanik.tu-darmstadt.de/GMT-Help/Archiv/11021.html.
The output from his shp2gmt version looks like this for a tiny extract
from a state map of the US:
>       Polygon #0      nVertices=17    nParts=1        cat=2   AREA=0  PERIMETER=0.224 STATESP020=3    STATE="Alaska"  STATE_FIPS="02"
-2.86129e+06    6.01613e+06
-2.86152e+06    6.01607e+06
-2.86163e+06    6.01615e+06
-2.86178e+06    6.01631e+06
-2.86248e+06    6.01724e+06
-2.86327e+06    6.01807e+06
etc.
What I can then do is write an awk script to substitute in the correct
-G and -W plotting parameters depending on the attributes. For instance
running this bit of awk over the above input file
{if ($0 ~ /Alaska/) printf "> -G175 -Wblack\n";
else print;}
should transform it into an input file where Alaska is plotted with a grey
fill. With more complicated lookups in the awk script, one can do pretty
sophisticated thematic mapping using this approach.
Best wishes,
Allan Hollander
On Tue, 25 Apr 2006, Trevor Wiens wrote:
> Grudgingly I'm using GMT after working through Dylan's example and am
> getting it to be somewhat functional.
> I will be needing to script the building of a large number of maps
> which I may store either in PostGIS or GRASS.
> I've noticed in the use of shp2gmt that there is no way of adding in a
> z attribute for use with the thematic colour assignment feature in GMT.
> If necessary I can extract bits based on different attributes and add
> them in separately, but it would be nice to be able to simply define a
> colour them once and be done with it. Any suggestions on how I can turn
> an attribute column in GRASS into a z-element that will be converted
> with shp2gmt would be appreciated.
> T
