[GRASSLIST:877] Re: GMT / GRASS use / shp2gmt
Dylan Beaudette
dylan.beaudette at gmail.com
Tue Apr 25 20:01:25 EDT 2006
Allan,
Great! This is certainly a step in the right direction.
Just for the record, to compile this new version of shp2gmt.c I added the
following to the makefile in the shputils dir:
shp2gmt_new: shp2gmt_new.c shpopen.o dbfopen.o
$(CC) $(CFLAGS) shp2gmt_new.c shpopen.o dbfopen.o $(LINKOPT) -o shp2gmt_new
where shp2gmt_new.c is the code you referenced.
works like a charm!
Cheers,
Dylan
On Tuesday 25 April 2006 04:14 pm, Allan Hollander wrote:
> Trevor,
> I'm a rank beginner at GMT but in my one exercise to date with it I
> learned the following. Mark Fenbers has modified the shp2gmt.c file to
> include the attribute info from the dbf file into the multi-segment
> separator of the psxy input file. His code is given in his message here:
> http://www.mechanik.tu-darmstadt.de/GMT-Help/Archiv/11021.html.
> The output from his shp2gmt version looks like this for a tiny extract
> from a state map of the US:
> > Polygon #0 nVertices=17 nParts=1 cat=2 AREA=0
> > PERIMETER=0.224 STATESP020=3 STATE="Alaska" STATE_FIPS="02"
> -2.86129e+06 6.01613e+06
> -2.86152e+06 6.01607e+06
> -2.86163e+06 6.01615e+06
> -2.86178e+06 6.01631e+06
> -2.86248e+06 6.01724e+06
> -2.86327e+06 6.01807e+06
> etc.
> What I can then do is write an awk script to substitute in the correct
> -G and -W plotting parameters depending on the attributes. For instance
> running this bit of awk over the above input file
> {if ($0 ~ /Alaska/) printf "> -G175 -Wblack\n";
> else print;}
> should transform it into an input file where Alaska is plotted with a grey
> fill. With more complicated lookups in the awk script, one can do pretty
> sophisticated thematic mapping using this approach.
> Best wishes,
> Allan Hollander
> On Tue, 25 Apr 2006, Trevor Wiens wrote:
> > Grudgingly I'm using GMT after working through Dylan's example and am
> > getting it to be somewhat functional.
> > I will be needing to script the building of a large number of maps
> > which I may store either in PostGIS or GRASS.
> > I've noticed in the use of shp2gmt that there is no way of adding in a
> > z attribute for use with the thematic colour assignment feature in GMT.
> > If necessary I can extract bits based on different attributes and add
> > them in separately, but it would be nice to be able to simply define a
> > colour them once and be done with it. Any suggestions on how I can turn
> > an attribute column in GRASS into a z-element that will be converted
> > with shp2gmt would be appreciated.
> > T
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
