[GRASSLIST:888] Re: v.segment
Trevor Wiens
twiens at interbaun.com
Wed Apr 26 02:34:27 EDT 2006
On Wed, 26 Apr 2006 17:32:11 +1200
Hamish <hamish_nospam at yahoo.com> wrote:
> As for speeding up table filling, I think it is faster to write all
> SQL statements to a file, then use just a single "db.execute input="
> call. If this does speed it up significantly, let us know & we can add
> the hint to db.execute help page. (insert "time" on the command line
> before the command to benchmark)
I ran a test and it is much faster.
Using a temporary file including the time to write it and run the
insert command against PostgreSQL for 537 records was < 1 second.
Running each command individually against the same database for the
same 537 records took 18 seconds.
Definitely a hint should be placed in the db.execute help page.
Thanks
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
