[GRASSLIST:894] Re: v.segment
Hamish
hamish_nospam at yahoo.com
Wed Apr 26 07:02:17 EDT 2006
> > As for speeding up table filling, I think it is faster to write all
> > SQL statements to a file, then use just a single "db.execute input="
> > call. If this does speed it up significantly, let us know & we can add
> > the hint to db.execute help page. (insert "time" on the command line
> > before the command to benchmark)
> I ran a test and it is much faster.
great.
> Using a temporary file including the time to write it and run the
> insert command against PostgreSQL for 537 records was < 1 second.
> Running each command individually against the same database for the
> same 537 records took 18 seconds.
> Definitely a hint should be placed in the db.execute help page.
done.
Hamish
