[GRASS-user] Tutorial & help needed::join tables (which are stored in postgres) and export result
Dylan Beaudette dylan.beaudette at gmail.com
Thu Aug 3 14:03:18 EDT 2006
Quick reply, as I have not completely finished these documents --- but feel
free to browse them here:
http://casoilresource.lawr.ucdavis.edu/drupal/node/264
there are some sample postgis queries which illustrate the use of spatial
operations, attribute joins, and such.
I am hoping to have a working set of my notes on interacting with USDA-NCSS
soil survey (SSURGO and STATSGO) within PostGIS, GRASS, etc.
I'll post an update when I make some changes.
Cheers,
Dylan
On Thursday 03 August 2006 05:30, wqual wrote:
> Dear list,
> I am still testing, what kind of database I should use for my work with
> GRASS/QGIS. As my experiences with sqlite3 where not that positive (large
> datasets took very much time to be read into sqlite), I started working
> with postgres (and my first impression is that it's far more faster). dbf
> is quick, but does not offer me the possibility to perform "table-join",
> which I need every day.
> I am not that experienced with pg, therefore, I would like to ask you folks
> some questions about "daily GIS work with postgres in GRASS":
> * How can I join pg-tables in GRASS, can I export a joined theme to make it
> permanent (for example, I would like to create a shapefile out of it which
> contains all information of the join)
> * Does anybody has experience with pg-frontends like knoda and pg_admin?
> Working with tables on the command-line is hard for people who used *other
> programmes* before ;)
> * what about large datasets: shapefiles with *qix-files seem to be loaded
> faster compared the same theme in GRASS with its attributes in postgres
> * tutorials available for this pg-stuff inside of GRASS?
> Any comments / hints are greatly appreciated!
> Best regards,
> Wolfgang
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
