[GRASS-user] distance along flow line to a particular feature
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Mon Aug 7 10:18:03 EDT 2006
I've never done it, but i guess you have to consider to use a script
using r.drain with the -n option....
draft of the script:
- extract x,y coordinates of each cell of your region (basin);
- foreach point run r.drain -n input=your_dem output=your_tmp_output
coordinate=x,y
- set to null the river cells in your_tmp_output by using r.mapcalc;
- run r.univar map=your_tmp_output and extract the maximum (it is the
number of cells to reach the river);
- write adding in a file the x,y,max values
- end of foreach
- import x,y,z to vector
- convert vector to raster
maybe too complicate?????
It is just a first idea....
Cheers,
Maxi
Godard Vincent wrote:
> Hi Grass users,
> I am quite new to Grass and I come here to get some hints and guidelines about
> a particular problem I have.
> I work on a watershed (on which I ran r.watershed, to get flow directions,
> accumulation...) and inside this watershed I define a linear feature (raster
> or vector) as the main stream.
> I would like to calculate the distance (along the hydrographic network) of
> each pixel of this watershed to the main stream. By distance I mean lenght
> calculated along the flow lines defined by the flow directions. The desired
> final output is a raster containing that distance to the main stream.
> Has anybody done such a thing with Grass previously?
> Thanks in advance,
> Vincent.
Dr. Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 14
Fax +41 (0)58 666 62 09
