[GRASS-user] distance along flow line to a particular feature
Maciej Sieczka
tutey at o2.pl
Mon Aug 7 11:14:01 EDT 2006
Godard Vincent napisa?(a):
> Hi Grass users,
> I am quite new to Grass and I come here to get some hints and guidelines about
> a particular problem I have.
> I work on a watershed (on which I ran r.watershed, to get flow directions,
> accumulation...) and inside this watershed I define a linear feature (raster
> or vector) as the main stream.
> I would like to calculate the distance (along the hydrographic network) of
> each pixel of this watershed to the main stream. By distance I mean lenght
> calculated along the flow lines defined by the flow directions. The desired
> final output is a raster containing that distance to the main stream.
> Has anybody done such a thing with Grass previously?
Markus Neteler has done something similar to what you describe.
http://grass.itc.it/grass60/screenshots/raster.php
(the "distance to water" one")
If that' what you mean, try asking him.
Maciek
