[GRASS-user] V.in.ogr error processing shape file from GEOBASE.
Any other experieinces?
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Aug 10 14:34:14 EDT 2006
David,
Does the attribute table contain any 'funny' characters ? anything that the
DBF driver or DBI driver would have problems with?
might try using a tool like dbfdump and awk to search for any oddities.
cheers,
dylan
On Thursday 10 August 2006 10:55, Sampson, David wrote:
> Hey Folks.
> I was wondering someone else can test out this dataset and let me know
> if they can make it import...
> Data source: http://www.geobase.ca/geobase/en/data/nrnc1.html
> Province: Ontario
> Archive: NRNC1_ON_SHAPE_en
> File: ROADSEG
> A free account is required to download the dataset.
> System:
> Linux (Gentoo)
> Grass 6.0.2 and 6.1
> Problem:
> When importing regularly with attribute tables the process halts part
> way through. Not all the vectors are imported. There are lots of holes
> left in the dataset. The error was refering to incorrect format of a
> column....
> Current Solution:
> Importing vector shape without attribute table. All the vecotrs import
> without holes. However, of course I'd like to have the attribute tables
> Next attempt to work around
> Never tried anything like this before but I'll try to just move the DBF
> file over to the DBF directory and try to connect to it manualy. I'm
> sure there will be a disconect somehow. If you have experience with this
> approach then let me know.
> Thanks
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
