[GRASS-user] Out of memory...
Dylan Beaudette
dylan.beaudette at gmail.com
Fri Aug 11 20:31:28 EDT 2006
On Thursday 10 August 2006 12:48, Harris Pappas wrote:
> Dylan,
> Thanks for the response. The number of points of my vector file (contour
> lines) is 7730470
> 3642623 is used by v.surf.rst.
> Could you explain my about the segmax value i didn't get it much ? As for
> the dmax. I've read in the manual the info about this value. As i put the
> resolution (25) in g.region the value changed automaticaly. Is that ok? or
> might causing problems ? For now i'm trying to see what will happen with
> the CV procedure but it takes very long as expected. About the segmentation
> procedure is being discribed in the manual, can i do anything about it? i
> guess no if i get it right. As you can see i'm new to GRASSGIS so sorry if
> i make silly questions.
> Best Regards,
> Harris
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Harris,
not sure why this is running out of memory - but you might try contacting the
lead dev responsible for the RST algorithms: Helena Mitasova.
Helena Mitasova <hmitaso at unity.ncsu.edu>
good luck,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
