[GRASS-user] Accentuating/adding topography to a raster image?
Michael Barton
michael.barton at asu.edu
Sun Aug 13 00:49:29 EDT 2006
The resolution of the region will have no effect on the resolution of the
screen for graphic output from GRASS, unless the region resolution (i.e.,
columns and rows) is less than the width and height of the screen in pixels.
If you are exporting this map (e.g., to a tif), then the resolution of the
region will have an effect on the resolution of the export.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Jonathan Greenberg <jgreenberg at arc.nasa.gov>
> Date: Sat, 12 Aug 2006 11:17:07 -0700
> To: 'Jachym Cepicky' <jachym.cepicky at centrum.cz>
> Cc: 'GRASS user list' <grassuser at grass.itc.it>
> Subject: RE: [GRASS-user] Accentuating/adding topography to a raster image?
> We are printing this out for a 9 foot by 5 foot wall installation, so we
> need to keep the resolution (as it stands it will output about a 130 dpi,
> the range for the printer is 100 to 200 dpi).
> --j
> Jonathan A. Greenberg, PhD
> NASA Postdoctoral Researcher
> NASA Ames Research Center
> MS 242-4
> Moffett Field, CA 94035-1000
> Phone: 415-794-5043
> AIM: jgrn3007
> MSN: jgrn3007 at hotmail.com
> -----Original Message-----
> From: Jachym Cepicky [mailto:jachym.cepicky at centrum.cz]
> Sent: Saturday, August 12, 2006 11:13 AM
> To: Jonathan Greenberg
> Subject: Re: [GRASS-user] Accentuating/adding topography to a raster image?
> what about resample your resolution?
> g.region res=*MORE*
> result could be still printable, but it would not be so big
> jachym
> On Sat, Aug 12, 2006 at 11:00:28AM -0700, Jonathan Greenberg wrote:
>> My main problem is the dem and image are both about 1.5 gb each -- am I
>> likely to run into problems with this?
>> Never played with nviz before, looks like I'll be trying it out tonight!
>> --j
>> MS 242-4
>> Phone: 415-794-5043
>> AIM: jgrn3007
>> From: Michael Barton [mailto:michael.barton at asu.edu]
>> Sent: Saturday, August 12, 2006 10:54 AM
>> To: Jachym Cepicky; Jonathan Greenberg
> image?
>> This is also automatically done in the GUI. Just put your shaded relief
> map
>> into the basemap field and your image into the drape map field.
>> Display and presto, you have a topographically shaded image.
>> You can also do this in nviz for an even more dramatic effect. Use a DEM
>> (not shaded relief) as a basemap/elevation map and use your image as a
> color
>> map for the topography.
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> From: Jachym Cepicky <jachym.cepicky at centrum.cz>
>>> Date: Sat, 12 Aug 2006 12:27:33 +0200
>>> To: Jonathan Greenberg <jgreenberg at arc.nasa.gov>
>> image?
>>> Hi,
>>> I use this approach:
>>> d.his h=your_map i=aspect
>>> or
>>> d.his h=your_map i=r_shaded_relief
>>> or run nviz and set the light source ;-)
>>> jachym
>>> On Sat, Aug 12, 2006 at 02:45:22AM -0700, Jonathan Greenberg wrote:
>>>> We're trying to add in a bit of topographic shading/illumination into
> an
>>>> image, and I was hoping to get some feedback on what algorithms work
> the
>>>> best? I tried a hillshade approach in ENVI, was pretty unimpressed
> with
>> it.
>>>> Any suggestions for a GRASS approach? Run r.sun and do some sort of
>> pixel
>>>> weighting?
>>>> --j
>>>> MS 242-4
>>>> Phone: 415-794-5043
>>>> AIM: jgrn3007
>>>> _______________________________________________
>>>> grassuser mailing list
>>>> http://grass.itc.it/mailman/listinfo/grassuser
>>> Jachym Cepicky
>>> e-mail: jachym.cepicky at centrum.cz
>>> URL: http://les-ejk.cz
>>> GPG:
> http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
>>> OFFICE:
>>> GDF-Hannover
>>> Mengendamm 16d
>>> 30177 Hannover
>>> Germany
>>> e-mail: cepicky at gdf-hannover.de
>>> URL: http://gdf-hannover.de
>>> Tel.: +49 511-39088507
> Jachym Cepicky
> GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
> OFFICE:
> GDF-Hannover
> Mengendamm 16d
> 30177 Hannover
> Germany
