[GRASS-user] display error wit latest cvs
Markus Neteler
neteler at itc.it
Tue Aug 15 15:54:48 EDT 2006
Carlos,
there was a change in the parser. This time you have to make
a *full* recompile including a full cleanup before compiling:
make distclean
Then it will work again.
Markus
On Tue, Aug 15, 2006 at 04:00:58PM -0300, Carlos Guâno Grohmann wrote:
> I just compiled the latest cvs, and get an error when I tried to
> display a raster. I set the region in the terminal and choose "zoom to
> current region". the error msg is this:
> Sorry, <map> is not a valid parameter
> ERROR: Required parameter <output> not set:
> (Name for output raster map).
> Description:
> Outputs basic information about a user-specified raster map layer.
> Usage:
> r.info [-rstghp] output=name [--overwrite]
> Flags:
> -r Print range only
> -s Print raster map resolution (NS-res, EW-res) only
> -t Print raster map type only
> -g Print raster map region only
> -h Print raster history instead of info
> -p Print raster map timestamp (day.month.year hour:minute:seconds) only
> --o Force overwrite of output files
> Parameters:
> output Name for output raster map
> Description:
> Usage:
> Flags:
> -r Print range only
> Parameters:
> while executing
> "close $rt"
> (procedure "GmRaster::display" line 40)
> invoked from within
> "GmRaster::display $node $mod"
> ("raster" arm line 2)
> invoked from within
> "switch $type {
> group {
> GmGroup::display $node $mod
> raster {
> labels {
> GmLabels::disp..."
> (procedure "GmTree::display_node" line 7)
> invoked from within
> "GmTree::display_node $n $mod"
> (procedure "GmGroup::display" line 25)
> invoked from within
> "GmGroup::display "root" $mod"
> (procedure "MapCanvas::runprograms" line 30)
> invoked from within
> "MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
> (procedure "MapCanvas::drawmap" line 43)
> invoked from within
> "MapCanvas::drawmap $mon"
> (procedure "MapCanvas::display_server" line 9)
> invoked from within
> ("after" script)
> thanks all.
> Carlos Henrique Grohmann - Guano
> Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
> Linux User #89721 - carlos dot grohmann at gmail dot com
> _________________
> "Good morning, doctors. I have taken the liberty of removing Windows
> 95 from my hard drive."
> --The winning entry in a "What were HAL's first words" contest judged
> by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
