[GRASS-user] display error wit latest cvs
Carlos "Guâno" Grohmann
carlos.grohmann at gmail.com
Tue Aug 15 15:58:42 EDT 2006
Thanks Markus.
I did it, it's all fine now, running 6.3-cvs
cheers
Carlos
On 8/15/06, Markus Neteler <neteler at itc.it> wrote:
> Carlos,
> there was a change in the parser. This time you have to make
> a *full* recompile including a full cleanup before compiling:
> make distclean
> Then it will work again.
> Markus
> On Tue, Aug 15, 2006 at 04:00:58PM -0300, Carlos Guâno Grohmann wrote:
> > I just compiled the latest cvs, and get an error when I tried to
> > display a raster. I set the region in the terminal and choose "zoom to
> > current region". the error msg is this:
> > Sorry, <map> is not a valid parameter
> > ERROR: Required parameter <output> not set:
> > (Name for output raster map).
> > Description:
> > Outputs basic information about a user-specified raster map layer.
> > Usage:
> > r.info [-rstghp] output=name [--overwrite]
> > Flags:
> > -r Print range only
> > -s Print raster map resolution (NS-res, EW-res) only
> > -t Print raster map type only
> > -g Print raster map region only
> > -h Print raster history instead of info
> > -p Print raster map timestamp (day.month.year hour:minute:seconds) only
> > --o Force overwrite of output files
> > Parameters:
> > output Name for output raster map
> > Description:
> > Usage:
> > Flags:
> > -r Print range only
> > Parameters:
> > while executing
> > "close $rt"
> > (procedure "GmRaster::display" line 40)
> > invoked from within
> > "GmRaster::display $node $mod"
> > ("raster" arm line 2)
> > invoked from within
> > "switch $type {
> > group {
> > GmGroup::display $node $mod
> > raster {
> > labels {
> > GmLabels::disp..."
> > (procedure "GmTree::display_node" line 7)
> > invoked from within
> > "GmTree::display_node $n $mod"
> > (procedure "GmGroup::display" line 25)
> > invoked from within
> > "GmGroup::display "root" $mod"
> > (procedure "MapCanvas::runprograms" line 30)
> > invoked from within
> > "MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
> > (procedure "MapCanvas::drawmap" line 43)
> > invoked from within
> > "MapCanvas::drawmap $mon"
> > (procedure "MapCanvas::display_server" line 9)
> > invoked from within
> > ("after" script)
> > thanks all.
> > Carlos Henrique Grohmann - Guano
> > Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
> > Linux User #89721 - carlos dot grohmann at gmail dot com
> > _________________
> > "Good morning, doctors. I have taken the liberty of removing Windows
> > 95 from my hard drive."
> > --The winning entry in a "What were HAL's first words" contest judged
> > by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
> Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
> ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18 - 38050 Povo (Trento), Italy
_________________
