[GRASS-user] Using v.external - still buggy?
Wolfgang Qual Wolfgang.Qual at gmx.net
Thu Aug 24 09:32:52 EDT 2006
Hello Moritz,
> If you don't need to analyse it in GRASS (in which case you are probably
> better off importing it anyway), why not just visualise it directly in
> QGIS without going through v.external ?
The reason, why I would like to use v.external:
We have a central server, where geodata is stored in oracle spatial. As the files are updated more or less often, we need to have a look at the data. Therefore, v.external would be great (and I do not know another possibility). Once loaded into QGIS in this way, I could use the select-tool and then export the selection to a grass-theme. Besides, I was curious, whether very big shapefiles - imported with v.external - would be displayed faster than the same theme imported with v.in.ogr.
Best regards,
Wolfgang
> Moritz
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
