[GRASS-user] gis.m errors in latest CVS
Markus Neteler
neteler at itc.it
Fri Aug 25 16:19:39 EDT 2006
Confirmed.
It happens in LatLong locations since the numbers are treated
as DMS and not decimal degrees.
Michael, could you take a look?
It would be nice to have it fixed before the next snapshot
is generated (in 7 hours from now). Otherwise I'll trigger
a new one once fixed.
Markus
On Fri, Aug 25, 2006 at 03:53:45PM -0300, Carlos Guâno Grohmann wrote:
> Just updated from CVS, and get GUI errors:
> Error in startup script: syntax error in expression
> "int(abs(7:56:32.529906S - 8:12:51.471615S)/0:00:03.002889)": missing
> close parenthesis at end of function call
> while executing
> "expr int(abs([lindex $region 0] - [lindex $region 1])/[lindex $region 4])"
> (procedure "MapCanvas::currentzoom" line 31)
> invoked from within
> "MapCanvas::currentzoom $mon"
> (procedure "MapCanvas::coordconv" line 24)
> invoked from within
> "MapCanvas::coordconv $mon"
> (procedure "MapCanvas::create" line 72)
> invoked from within
> "MapCanvas::create"
> (procedure "Gm::startmon" line 11)
> invoked from within
> "Gm::startmon"
> (procedure "Gm::create" line 74)
> invoked from within
> "Gm::create"
> (procedure "main" line 30)
> invoked from within
> "main $argc $argv"
> (file "/usr/local/grass-6.3.cvs/etc/gm/gm.tcl" line 528)
> thanks
> Carlos Henrique Grohmann - Guano
> Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
> Linux User #89721 - carlos dot grohmann at gmail dot com
> _________________
> "Good morning, doctors. I have taken the liberty of removing Windows
> 95 from my hard drive."
> --The winning entry in a "What were HAL's first words" contest judged
> by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
