[GRASS-user] gis.m errors in latest CVS
Markus Neteler
neteler at itc.it
Mon Aug 28 07:22:27 EDT 2006
followup: a fix was posted to CVS on Sunday and the snapshots regenerated.
Markus
Markus Neteler wrote on 08/25/2006 10:19 PM:
> Confirmed.
> It happens in LatLong locations since the numbers are treated
> as DMS and not decimal degrees.
> Michael, could you take a look?
> It would be nice to have it fixed before the next snapshot
> is generated (in 7 hours from now). Otherwise I'll trigger
> a new one once fixed.
> Markus
> On Fri, Aug 25, 2006 at 03:53:45PM -0300, Carlos Guâno Grohmann wrote:
>> Just updated from CVS, and get GUI errors:
>> Error in startup script: syntax error in expression
>> "int(abs(7:56:32.529906S - 8:12:51.471615S)/0:00:03.002889)": missing
>> close parenthesis at end of function call
>> while executing
>> "expr int(abs([lindex $region 0] - [lindex $region 1])/[lindex $region 4])"
>> (procedure "MapCanvas::currentzoom" line 31)
>> invoked from within
>> "MapCanvas::currentzoom $mon"
>> (procedure "MapCanvas::coordconv" line 24)
>> invoked from within
>> "MapCanvas::coordconv $mon"
>> (procedure "MapCanvas::create" line 72)
>> invoked from within
>> "MapCanvas::create"
>> (procedure "Gm::startmon" line 11)
>> invoked from within
>> "Gm::startmon"
>> (procedure "Gm::create" line 74)
>> invoked from within
>> "Gm::create"
>> (procedure "main" line 30)
>> invoked from within
>> "main $argc $argv"
>> (file "/usr/local/grass-6.3.cvs/etc/gm/gm.tcl" line 528)
>> thanks
>> Carlos Henrique Grohmann - Guano
>> Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
>> Linux User #89721 - carlos dot grohmann at gmail dot com
>> _________________
>> "Good morning, doctors. I have taken the liberty of removing Windows
>> 95 from my hard drive."
>> --The winning entry in a "What were HAL's first words" contest judged
>> by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
