[GRASS-user] nviz max resolution ppm image dump
Hamish
hamish_nospam at yahoo.com
Mon Aug 28 22:13:40 EDT 2006
William Hargrove wrote:
> My nviz dies with a segfault when I try to dump an image as maximum
> resolution ppm.
> I have this same problem with grass 6.1 under FC 5, and under grass
> 5.4 under FC 4.
what's the date on the 6.1? 6.1.0 or 6.1-cvs? This was an old known
problem on 64bit &/or big endian (Mac G5), I had thought that it was
fixed by Glynn & crew some months ago.
> I can dump the other formats just fine.
> The map products look great on the screen, but aren't much use if I
> can't get them into a high-res image file.
> Does anyone have any advice on this problem?
http://intevation.de/rt/webrt?serial_num=3041
perhaps that bug referes to a slightly different problem?
Hamish
