[GRASS-user] [GRASSLIST:1183] how to rotate raster in GRASS ?
Jarek Jasiewicz
jarekj at amu.edu.pl
Thu Aug 31 12:29:09 EDT 2006
Pierluigi De Rosa napisa?(a):
> Thanks Jarek for your answer!!
> Yes I have to rotate a DEM, so I wont to lose the orientation North South...
> I would to rotate a DEM of a specific angle.
> R can do it?
> After importing DEM in R which is the R command to rotate a spatial data
> frame??
> Pierluigi
I have did it on that way:
DEM imported you will have as SpatialGridDataFrame
1) convert it to matrx
matrix=as.matrix(yoDEM)
2) next transpose it
tmatrix=t(matrix)
3) see what you have:
image(tmatrix)
that all - convert it to data grame again, or export from srictly from R
but if you want rotate to spacific angle - for example 37 grads hmmm....
this is not a way
mayby try georeference .... but aI'm not sure about result
As I remember ArcView/Info has posibilities to rotate raster during
georeferencing mayby use it...
regards
Jarek
