[GRASS-user] problem with installing GRASS 6.2 and Fedora 6
Brad Douglas rez at touchofmadness.com
Sun Dec 3 18:18:21 EST 2006
On Sat, 2006-12-02 at 22:05 -0600, Sitansu B Pattnaik wrote:
> Dear All,
>  I have been getting valuable information from the list for more than
> a year now. Recently, I upgraded to Fedora 6 with a clean install. I
> tried to run the following command but recieved an error. I would
> appreciate any feedback. Grass package is looking for Gdal version 1.3
> libraries.
> Thank you,
> Sitansu
> Install command:
> yum localinstall grass-6.2.0-1.fdr.fc6.i386.rpm
> gdal-grass-1.3.2-1.fdr.fc6.i386.rpm
> Output:
> Loading "installonlyn" plugin
> Setting up Local Package Process
> Examining grass-6.2.0-1.fdr.fc6.i386.rpm: grass -
> 1:6.2.0-1.fdr.fc6.i386
> Examining gdal-grass-1.3.2-1.fdr.fc6.i386.rpm: gdal-grass -
> 1:1.3.2-1.fdr.fc6.i386
> Marking grass-6.2.0-1.fdr.fc6.i386.rpm to be installed
> Setting up repositories
> Reading repository metadata in from local files
> Marking gdal-grass-1.3.2-1.fdr.fc6.i386.rpm to be installed
> Resolving Dependencies
> --> Populating transaction set with selected packages. Please wait.
> ---> Package gdal-grass.i386 1:1.3.2-1.fdr.fc6 set to be updated
> ---> Package grass.i386 1:6.2.0-1.fdr.fc6 set to be updated
> --> Running transaction check
> --> Processing Dependency: fftw3 >= 3.1 for package: grass
> --> Processing Dependency: lesstif >= 0.95 for package: grass
> --> Processing Dependency: proj >= 4.4.9 for package: grass
> --> Processing Dependency: libgdal.so.1 for package: gdal-grass
> --> Processing Dependency: proj for package: gdal-grass
> --> Processing Dependency: gdal >= 1.3 for package: grass
> --> Processing Dependency: geos >= 2.1.1 for package: grass
> --> Restarting Dependency Resolution with new changes.
> ---> Package lesstif.i386 0:0.95.0-10.fc6 set to be updated
> ---> Package geos.i386 0:2.2.1-5.fc6 set to be updated
> ---> Package proj.i386 0:4.4.9-4.fc6 set to be updated
> ---> Package fftw.i386 0:3.1.2-3.fc6 set to be updated
> --> Processing Dependency: libXp.so.6 for package: lesstif
> ---> Package libXp.i386 0:1.0.0-8 set to be updated
> --> Finished Dependency Resolution
> Error: Missing Dependency: libgdal.so.1 is needed by package
> gdal-grass
> Error: Missing Dependency: gdal >= 1.3 is needed by package grass
You also need to install the gdal RPM as well.  grass-gdal is only a
plugin for gdal that allows it to interpret GRASS format.
Brad Douglas <rez touchofmadness com>                    KB8UYR/6
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
