[GRASS-user] problem with installing GRASS 6.2 and Fedora 6
Sitansu B Pattnaik spattnaik at forestone.com
Sun Dec 3 23:30:47 EST 2006
Thank you Brad. I got Grass and gdal working finally. The install proved to
be very simple this time.
Sitansu
My steps:
1. Downloaded gdal-grass-1.3.2-1.fdr.fc6.i386.rpm,
grass-6.2.0-1.fdr.fc6.i386.rpm and geos-2.2.3-1.fc6.i386.rpm from
http://grass.ibiblio.org/grass62/binary/linux/fedora6/
wget
http://grass.itc.it/grass62/binary/linux/fedora6/gdal-grass-1.3.2-1.fdr.fc6.
i386.rpm
wget
http://grass.itc.it/grass62/binary/linux/fedora6/grass-6.2.0-1.fdr.fc6.i386.
rpm
wget
http://grass.itc.it/grass62/binary/linux/fedora6/max_rpms/geos-2.2.3-1.fc6.i
386.rpm
2. Downloaded gdal-1.3.2-2.fc6.i386.rpm and ogdi-3.1.5-1.fc6.i386.rpm
http://fr2.rpmfind.net//linux/RPM/local/fedora/6/i386/gdal-1.3.2-2.fc6.i386.
html
http://fr2.rpmfind.net//linux/RPM/local/fedora/6/i386/ogdi-3.1.5-1.fc6.i386.
html
wget
ftp://fr2.rpmfind.net/linux/local/fedora/6/i386/gdal-1.3.2-2.fc6.i386.rpm
wget
ftp://fr2.rpmfind.net/linux/local/fedora/6/i386/ogdi-3.1.5-1.fc6.i386.rpm
3. Edited yum configuration file to turn off gpg checking as
gdal-grass-1.3.2-1.fdr.fc6.i386.rpm is not signed.
joe /etc/yum.conf and changed to
gpgcheck=0
Or
sed -i s/gpgcheck=.*/gpgcheck=0/ /etc/yum.conf
4. Installed using yum
yum localinstall gdal-1.3.2-2.fc6.i386.rpm
gdal-grass-1.3.2-1.fdr.fc6.i386.rpm grass-6.2.0-1.fdr.fc6.i386.rpm
geos-2.2.3-1.fc6.i386.rpm ogdi-3.1.5-1.fc6.i386.rpm
5. SElinux was causing access voilation. Hence, disabled it by using the
GUI.
Or
joe /etc/selinux/config
Then changed
SELINUX=permissive
6. Enabled gpg check
sed -i s/gpgcheck=.*/gpgcheck=1/ /etc/yum.conf
GRASS 6.2 is operational now.
-----Original Message-----
From: Brad Douglas [mailto:rez at touchofmadness.com]
Sent: Sunday, December 03, 2006 5:18 PM
To: spattnaik at forestone.com
Cc: grassuser at grass.itc.it
Subject: Re: [GRASS-user] problem with installing GRASS 6.2 and Fedora 6
On Sat, 2006-12-02 at 22:05 -0600, Sitansu B Pattnaik wrote:
> Dear All,
>  I have been getting valuable information from the list for more than
> a year now. Recently, I upgraded to Fedora 6 with a clean install. I
> tried to run the following command but recieved an error. I would
> appreciate any feedback. Grass package is looking for Gdal version 1.3
> libraries.
> Thank you,
> Sitansu
> Install command:
> yum localinstall grass-6.2.0-1.fdr.fc6.i386.rpm
> Output:
> Loading "installonlyn" plugin
> Setting up Local Package Process
> Examining grass-6.2.0-1.fdr.fc6.i386.rpm: grass -
> 1:6.2.0-1.fdr.fc6.i386
> Examining gdal-grass-1.3.2-1.fdr.fc6.i386.rpm: gdal-grass -
> 1:1.3.2-1.fdr.fc6.i386
> Marking grass-6.2.0-1.fdr.fc6.i386.rpm to be installed Setting up
> repositories Reading repository metadata in from local files Marking
> gdal-grass-1.3.2-1.fdr.fc6.i386.rpm to be installed Resolving
> Dependencies
> --> Populating transaction set with selected packages. Please wait.
> ---> Package gdal-grass.i386 1:1.3.2-1.fdr.fc6 set to be updated
> ---> Package grass.i386 1:6.2.0-1.fdr.fc6 set to be updated
> --> Running transaction check
> --> Processing Dependency: fftw3 >= 3.1 for package: grass Processing
> --> Dependency: lesstif >= 0.95 for package: grass Processing
> --> Dependency: proj >= 4.4.9 for package: grass Processing
> --> Dependency: libgdal.so.1 for package: gdal-grass Processing
> --> Dependency: proj for package: gdal-grass Processing Dependency:
> --> gdal >= 1.3 for package: grass Processing Dependency: geos >=
> --> 2.1.1 for package: grass Restarting Dependency Resolution with new
> --> changes.
> ---> Package lesstif.i386 0:0.95.0-10.fc6 set to be updated Package
> ---> geos.i386 0:2.2.1-5.fc6 set to be updated Package proj.i386
> ---> 0:4.4.9-4.fc6 set to be updated Package fftw.i386 0:3.1.2-3.fc6
> ---> set to be updated
> --> Processing Dependency: libgdal.so.1 for package: gdal-grass
> --> Processing Dependency: gdal >= 1.3 for package: grass Processing
> --> Dependency: libXp.so.6 for package: lesstif Restarting Dependency
> --> Resolution with new changes.
> ---> Package libXp.i386 0:1.0.0-8 set to be updated
> --> Processing Dependency: gdal >= 1.3 for package: grass Finished
> --> Dependency Resolution
> Error: Missing Dependency: libgdal.so.1 is needed by package
> gdal-grass
> Error: Missing Dependency: gdal >= 1.3 is needed by package grass
You also need to install the gdal RPM as well.  grass-gdal is only a plugin
for gdal that allows it to interpret GRASS format.
Brad Douglas <rez touchofmadness com>                    KB8UYR/6
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
