[GRASS-user] Library problem
J Dougherty jwd at surewest.net
Mon Dec 4 05:37:01 EST 2006
I've just downloaded the current Grass 6.2 (compiler produces grass63 as the
executable).  I also have updated GDAL and PROJ.  Grass configures without
problems and compiles with a single warning of an error in .../proj.  I'm
running SuSE 10.1 on an intel based system with a GB of RAM.
Running grass63 resuls in the following message when starting:
"g.region: error while loading shared libraries: libgdal.so.1: cannot open
shared object file: No such file or directory"
libgdal.so.1 exists as an alias for libgdal.so.1.10.0 in /usr/local/lib, so
evidently g.region is looking in the wrong.
I'ld to know how to fix this.
Thanks,
JWDougherty
