[GRASS-user] Library problem
    Yves Jacolin
    yjacolin at free.fr
    Mon Dec  4 05:33:02 EST 2006
Le Lundi 4 Décembre 2006 11:37, J Dougherty a écrit :
> I've just downloaded the current Grass 6.2 (compiler produces grass63 as
> the executable).  I also have updated GDAL and PROJ.  Grass configures
> without problems and compiles with a single warning of an error in
> .../proj.  I'm running SuSE 10.1 on an intel based system with a GB of RAM.
> Running grass63 resuls in the following message when starting:
> "g.region: error while loading shared libraries: libgdal.so.1: cannot open
> shared object file: No such file or directory"
> libgdal.so.1 exists as an alias for libgdal.so.1.10.0 in /usr/local/lib, so
> evidently g.region is looking in the wrong.
> I'ld to know how to fix this.
> Thanks,
> JWDougherty
You can try to add the path of gdal to /etc/ld.so.conf and run ldconfig after
in root.
Y.
Yves Jacolin
http://yjacolin.gloobe.org
