[GRASS-user] Library problem
J Dougherty jwd at surewest.net
Mon Dec 4 20:37:05 EST 2006
On Monday 04 December 2006 02:33, Yves Jacolin wrote:
> Le Lundi 4 Décembre 2006 11:37, J Dougherty a écrit :
> > I've just downloaded the current Grass 6.2 (compiler produces grass63 as
> > the executable).  I also have updated GDAL and PROJ.  Grass configures
> > without problems and compiles with a single warning of an error in
> > .../proj.  I'm running SuSE 10.1 on an intel based system with a GB of
> > RAM.
> > Running grass63 resuls in the following message when starting:
> > "g.region: error while loading shared libraries: libgdal.so.1: cannot
> > open shared object file: No such file or directory"
> > libgdal.so.1 exists as an alias for libgdal.so.1.10.0 in /usr/local/lib,
> > so evidently g.region is looking in the wrong.
> > I'ld to know how to fix this.
> > Thanks,
> > JWDougherty
> Hi,
> You can try to add the path of gdal to /etc/ld.so.conf and run ldconfig
> after in root.
> Y.
Yves,
Thanks for the ideas.  The path was already in /etc/ld.so.con.  The cure was
running ldconfig.  Thank you again.
John
